Any way to remove themes?
To completely get rid of a theme, you have to flash the ROM again. You can flash a new theme over an existing one, but if the new theme isn't as in depth as the first one, some of the original theme will remain.
For example, theme A covers notifications, first layer menus, second layer menus, etc. Theme B covers notifications and first layer menus only. After flashing theme B, you will have theme B first layer menus AND theme A second layer menus.
Thanks Kevin. So to be totally safe to have the same setup on different themes I should flash ROM, theme, and add-ons for each theme?
I just flashed the ROM again and installed the theme i wanted. Everything is the way i wanted now. I couldnt figure out anyway to remove it.
When you flash a different ROM through clockworkmod recovery it wipes away the theme. If you had a theme and just wanted to run the ROM, say superclean 2.4 with no theme, you would just boot to recovery, scroll to install zip from sd card, choose sc 2.4, hit the power button, wait for the install to complete, reboot phone and theme will be gone, you will be running just the ROM with no theme. If you want to run a different theme you can just flash the different theme, but it may not fully take. Kevin Gossett did a great job of explaining this one page back in this thread at post #20
EDIT - And I also gave you an answer at the top of my post in #12
Jayarealways
