Any way to silence incoming call on screen?
TheCROW163
Active member
May 7, 2013
39
Hey All,
I know that I can press the volume button or power button in order to silence an incoming call ringtone.
I also know about the flip to silence feature, but that only works when the phone is lying on a surface.
Is there a way to do this when the phone is in my hand for example? I have a case that covers the side buttons so I need an onscreen option to do this quickly.
Any alternative?
Thank you kindly.
Hey All,
Any alternative?
Thank you kindly.
I think you can still flip the phone or just hit the ignore
Sent from my Galaxy S4 White - using Tapatalk
Hi,
You can enable an option which allows you to simple cover the screen with your hand and the call will be silenced!
I cannot see an ignore button on my screen! Should there be one?
I tried to flip it while holding it in my hand just now and it worked! Thanks!!
Hi,
Can you please point me to that setting?
Why would you want a case that covers the buttons? You kind of need them.
My case covers the buttons but I can still press them, but when in a rush to silence the phone in a bad time, on screen option is quicker :)
Thank you All for your replies.
The setting they are referring to is located at: Settings --> My Device --> Motions and Gestures --> Select Palm Motion "on"
Click it on, but then tap the selection for 2 additional settings.
