Any way to tell which app using battery on Gear 2
prubin
150
I mostly get very good battery life. Usually 70-80% left every night. However, sometimes it is down to 10-15%. Is there any way to tell which apps are using battery? Or does anyone know which apps are especially bad for battery life?
Especially bad are apps on the gear that use the cam recorder.
For me most of all alarm/timer apps.
Also when bluetooth is NOT connected for a long time.
I have noticed that when it seems to be using a lot of battery a reset can help.
heritagevine04
