Any way to wake phone with button other than power?
Darth Mo
1,319
58
48
Less then four months and power button is already wonky. Replacement on the way so whatever.
It works eventually, but it's pretty annoying. Is there an app out there that will let the volume rocker or camera button wake the phone?
I'm not rooted.
I'm not rooted.
Don't know of any way to do it on a non-rooted device. If you root though, most of the roms over at xda seem to have that kind of functionality built in.
Sent from my EVO using Android Central Forums
Yes, there is an app in the play store called fix broken power button,I used it when my ns4g power button failed, no root required
Sent from my Nexus S 4G using Android Central Forums
Try Awesome On Off. You don't use your power button and it will bypass the lock screen (no root required either). I've been using it for a couple of months now and I really like it.
Sent from my HTCEVOV4G using Android Central Forums
Is there any way to make it not so sensitive?
Root it, mean rom wakes with camera button
Sent from the blob fish (if you don't know what a blobfish is, Google it)
heritagevine07
