Anybody else using Good Lock?
New update out for those that have to apk it (v14). Not a huge amount of changes but you now have much more colour options for routines, which is a great addition.
Have you tried using the flashlight yet on the updated version ?
Thanks for checking. It broke it for many others, mine included.
I am getting horrendous battery drain from it though. I'll have to go back a version.
I downloaded it last night and my s7 would not unlock with the password and I tried to change it in the management website. Now I'm going to redownload 60+ gb of my movies and I don't have home Internet so I'm going to sit in a coffee shop for a bit
24.0.15 is out now which apparently fixes the torch thing. Not sure if it fixes the battery drain yet.
It just installed on my newly factory reset exercise - I took an instant dislike to what it did to the display, all the colour changes, all the notifications that seemed to start popping up and within 5 minutes uninstalled it!
You can do a lot of edits to make it look like you want. I have no at things turned off but it makes the recent apps and the top status bar look so much better. Also makes the fingerprint unlock a lot quicker.
cinemacritic
