Anyone got FoxFi to work?
I just checked its not for my device n here's what it says
Sent from my SPH-M930BST using Android Central Forums
I think boost still falls under the sprint category...
Sent from my SAMSUNG-SGH-I747 using Android Central Forums
That's awesome... hope it works well for you...
Do you use this foxfi instead of using the hotspot on my phone? why would i use this? do i save on not turning on my data plan with att?
Foxfi is a free app in the play store... it lets us your phones data plan as a WiFi hotspot.... if u use the built in one then you would have to have that feature added to your AT&T account and its like $30 more....
That's weird. Hmm, mine works. Sorry
Use the sprint apk. Works fine with att phones. Just make sure you go back to the app store google play and get the add on.
Works fine for me used it today to play cod bo online and not one problem and I'm not rooted
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
I have a S2Epic 4G with Sprint. I have downloaded FoxFi through their website...and I got the app on my phone, but when I try to connect my devices it says there is no internet connection! I am not connected to a wireless router as I have made my phone forget all connections...Ideas?
I believe foxfi doesn't work with sprint phones.... somehow sprint has managed to block it...
It does work I think you just have to get the app my bro uses it on his photon unrooted all the time.
Sent from my paranoid S3
It has to be the foxfi add on through market. Or you can directly download from their site.
Then make sure your tablet isn't on Honeycomb because then that's a separate app. I would tell you which one but I don't have my tablet on me.
I checked FoxFi Installer] where you can download FoxFi latest version 1.91.3, but there is a note at bottom of the page: "Support for the new Galaxy S3 and the new ICS update for Epic Touch are being worked on. Should be compatible soon in a future update."
Direct46
