Anyone having problems with Air Gestures on Galaxy S5?
stargate09
3
Hi when I enable Air Browse on my S5 it will not work. Not even getting the Air Browse icon on my phone. Please help.
Go to settings; you will see motions and gesture icon. There you enable air gestures
Sent from Space Gray design marvel of 2013
One important thing worth mentioning: air browse only worked for me for the standard internet app. It did not work in chrome.
i can't speak for air gestures, but i do have air wake up turned on. i noticed it's very picky about gestures, and won't work in bright sunlight, even if it's indirect sunlight. it usually won't work either when i'm holding the phone, the phone has to be placed on a surface or held very steady.
i think the built-in air gestures is mostly gimmicky, but there are apps that seem to work well with it, especially air control that can forward/rewind music tracks based on gestures.
I haven't had any issues with mine as of yet. But as stated above I believe it only works with the standard Internet app. Not all apps support it.
Sent from my Galaxy S5
On mine it's just called Internet. AT&T version here running latest software pushed from the carrier.
Sent from my SAMSUNG-SM-G900A using Tapatalk
Yes I can't get it either. My volume will not zoom in or out as it's suppose too according to page 90 of the sprint User Guide? Does yours work?
I'm sure they've tried that lol. I know I have and still not working. It's worked couple weeks ago. Other settings turned on will turn other settings like these off but I've tried everything and still nothing
#Posted via the Android Central App
air browse not support for music player can give d solution... it works for gallery but not working for music player
I am also having problems with my motion sensor after I turned it on. I am having issues as Its eating up my battery, whenever I am keeping my mobile in my pocket, at the slightest of motion it turns on without my knowledge. I tried turning off the motion sensor but my mobile still wakes up at the slightest of motion when kept in my pocket.
Is there any other way I can put off motion sensor screen wake up??
kiki2025
