Anyone with the playpad?
I've had the exact same experience. I'm running 4.2.1 on an Asus Transformer.
I paired the controller and it went smoothly, working the first time.
I then played a game for half an hour. Again, everything working perfectly.
I had to take a phone call, so I put the tablet and controller to sleep.
Came back to resume play and nothing!
I've unpaired and repaired over and over and it simply won't work!
I've tried pairing it with other devices too.
While it does work with my iPhone, it displays the same "pairing but not connecting" behaviour with my laptop under either the controller or mouse modes. Both modes show the Nyko controller as being paired, but any application I try to use it with tells me there is no device connected.
This is very frustrating.
How do I restart your android or have it restart it in factory mode, will I still be able to keep the games I downloaded pls respond I'm in need of help thanks
anything tied to your Google account, you should be able to redownload. As for in app purchases [for example if you bought an upgraded machine gun in a FPS shooter] that would depend on the specific app.
to restart hold down the power button [turn it off , then on.
Resetting a device to factory defaults is a big step. If you don't feel comfortable doing it you may want to grab a friend who is tech savy to help you make sure you have all your data safely backed up. here are google's instructiosn for the N10
https://support.google.com/nexus/10/answer/2935993?hl=en
Can confirm the issue still exsists on 4.2.2... For what its worth, i made a simple app which runs a few commands to erase your bluetooth settings and restarts the bluetooth daemon.. A step up from doing a full factory reset.
Really hope this gets fixed though...
Hope the app is useful, i'm providing it 'as-is' and it does require root (su) if anyone wants the source code, let me know in a pm and i'll be happy to send you the eclipse folder.
I will be posting this with some other tools im working on to google play some time in the near future, when i have a spare $20 for the registration fee
there is a way to go through and delete your Bluetooth files and settings instead of factory resetting the phone. You have to go in and manually do it yourself. Its either go delete the Bluetooth files or do a factory reset is the only way cause the Bluetooth saves all the devices and settings
opegamani
