Anyway to change the water droplet sound when making a phone call
elvis1935
182
4
It's so annoying to hear those water droplets when trying to make a phone call. Is there anyway to get realtones?
Does anyone know how to fix it or do you all like it.
I don't have a clue what you're talking about. I hear nothing. Try this... Settings/sound at the bottom, is system sounds. Unchecked all of them and see if it goes away. The first thing I do when setting up my phone, is to turn off the system sounds. I only have sound on for notifications and calls. It must work because I've never heard the droplets.
If you want, you can add them back one at a time until you find the culprit.
____________
Just Flash It !!!
Re: Anyway to change the water droplet sound when making a phone
This does it. Turn system sounds all the way down.
____________
Just Flash It !!!
____________
Just Flash It !!!
I think he means when he dials the numbers it makes the droplets sound lol. elvis1935, best bet is to turn off or lower the sound?
Your right I will try that thanks.
go to your phone app
press menu
call settings
call alert
call status tones
uncheck call connect tone ;)
download Go Dialer EX and you will get normal tones when pressing the number keys and there are different themed appearances you can choose from
This is the easiest no rooting fix for now
r3dpuk3
