No I wouldn't worry..I use AoD tap to display. Do you think it uses too much battery even when it's set to tap to display?!
No.... Never worried about before and I don't plan to startI use AoD tap to display. Do you think it uses too much battery even when it's set to tap to display?!
It made me wonder because every battery saving tips article, tells you to disable it.No I wouldn't worry..
That's if you use AOD always and want to squeeze every bit of battery out of your phone , but having it set to tap and display don't even worry about it .It made me wonder because every battery saving tips article, tells you to disable it.
But since I'm only tapping it and it isn't always. I just like using it since they took away the LED indicator with the S10 phones
Even if it's always on it doesn't matter that matchIt made me wonder because every battery saving tips article, tells you to disable it.
You will be fineWith my S9+, it use to kind of eat a lot of battery.
AOD uses about 1% battery every 2 hours (if you leave it on all the time, which I do).
I wouldn't worry about it.
