AOKP Screenshots!
Actually there is no need for that. Go to e4gtcm.blogspot.com and click on tools or install guide and find the EL26 or EL29 direct boot kernel. Using the same steps you can boot directly into EL based CWM and flash away!
Sent from my AOKP'd D710
Either way you have to download a kernel with cwm, use mobile Odin, flash it, boot into recovery, flash new rom. It's the exact same thing.
Well, minus the battery pull but you don't even actually have to do a battery pull if you just hold volume up and power when you see the flashing light.
So with direct boot you get to skip holding up volume and power...
-AOKP milestone 6-
Not a ton of screen time but not too dang bad at all for 2 hours.
-AOKP milestone 6-
DEF3NDER, What is your CPU and screen brightness and/or any other relevant settings? I am only able to get around 7 to 9 hours with 1.5 hours screen on
Sent from my SPH-D710 using Android Central Forums
I keep my brightness all the way down unless I'm in direct sunlight. I'm just running on demand with stock cpu settings. All AOSP based roms give me amazing battery life in contrast to touchwiz.
The battery life you are experiencing doesn't seem right at all. There has to be some underlying issue there. How else would I be getting 3 times the battery life as you?
**Aokp ICS with Jellybean bolt-ons**
Are we the only ones running AOKP? I also picked the clock from times's build. And the CM papers came from CM9
adamgilcrist57890
