[APP] Roam Control Optimus (NO ROOT REQUIRED)
Can this be updated to have the icon from ReBORN and have the name changed from LG Hidden Menu?
Where is the newest release of this software? I can't find it?
Thanks
Update, I found it. I do have a question though, am i supposed to install both files? On my Optimus I have an app called "LG Hidden menu" (the old name) but I do not see the other file you posted.
Thanks I have been using this in RebornRom and it is great. She wanted this app too but did not want her phone rooted. Now that I found this thread I added it to my wife's Optimus S she and I thank you.
Just downloaded and started using this program. So far it does seem to help where there is otherwise marginal sprint service and comparatively better verizon service -- so thanks and thumbs up to Nick! Now I just have to remember to turn off the app when I leave work and head home...
As others have stated, unfortunately the 3G coverage is still pretty weak in these same locations. I checked out the alternate program/thread that Nick set up but it seemed kind of complicated to an android newbie like myself.
I used dropbox to download the program onto my pc then installed it on my optimus. Seemed pretty straightforward.
Ok so I was prompted to upgrade to gingerbread today by the optimus. So far, I have refused the upgrade because I want to make sure that this app continues to work.
Does anyone have any idea how gingerbread will affect this app? If anyone has upgraded the software, please post here and let us know. Thanks.
Gingerbread update had no effect that I can tell on the app (that I've had installed pretty much since the first day OP posted it). IIRC, it's essentially just a shortcut straight to the roaming related hidden LG menus. So long as LG/sprint doesn't much around with those menus, then the app shouldn't be affected.
mersy78
