April's update
Mustang, how can you tell what the latest Google play services you have?
Some in reddit are reporting an issue with GPS and Google play constantly showing up with the GPS flickering back and forth, something about Google play services not being "white listed"?
25.14.62 is the last version of Google play services that I have?
Settings > Apps > Google Play Services. Scroll down to bottom to see version number. The version you have is latest unless you're signed up for Google Play Services beta. Beta is currently on 25.15.32.
Follow claykin outline
Reactions: rsmin and claykin
I'm signed up for the Google Play Services beta because I'm eagerly awaiting Google fixing the Android Auto (wireless) disconnect and audio skipping issues. For the last several releases the notes claim they're fixing AA connectivity issues but I'm still seeing less than acceptable connection reliability. Anyone else? Unfortunately my BMW won't allow a wired AA connection.
I'm signed up for the Google Play Services beta because I'm early awaiting Google fixing the Android Auto (wireless) disconnect and audio skipping issues. For the last several releases the notes claim they're fixing AA connectivity issues but I'm still seeing less than acceptable connection reliability. Anyone else? Unfortunately my BMW won't allow a wired AA connection.
Mine skips also. At least we have a half baked Gemini that sucks.
You have Gemini in AA? Mine is still on Assistant. I'm signed up for AA beta. Impatiently waiting.... More important is Google fixing the connectivity problems.
I had to stop using AA Wireless in my Explorer, because it causes the SYNC3 system to have all kinds of problems. At least it works wired. I just hate plugging it in and charging all of the time. Plus I constantly forget to take my phone with me when I get out of the car...
Reactions: mlblack16
I ordered this off Amazon.
https://www.aawireless.io/en/produc...koXBw_KS9QTDdYyoM9f9XBTvEJu1WsN0aAgwDEALw_wcB
Hopefully I don't have the issues you're experiencing but wanted to give it a try vs plugging/unplugging the phone every time.
I did read somewhere on Reddit that there was an issue with Samsung devices wanting to shut off wireless after a certain amount of time causing you to have to re-wake the device. Or something to that effect. I'll have to find what they said was the workaround. I think they created a bixby routine for it. For example, for some reason, the factory wireless charging pad in my Mazda doesn't work if NFC is turned on, so I made a routine that shuts off NFC when connecting to the Mazda.
Thanks!
lluigidagg
