I've had my Incredible hooked up to my laptop via my Storm1 old usb and it's taken FOREVER to charge. I had like 16% battery life left this morning wehn I put it on around 10:00 and it's been on there the majority of the day and at 3:50 it's only at 51%. Should it really take that long?
It's only charging at 500mah which is .5 amps. The wall adapter that came with the phone is rated at 1 amp. So naturally it's going to take longer to charge (twice as long). I have the exact same setup you're talking about but I don't think it takes that long. Usually I'd be around 65-70% charged after that long.
Does your screen turn off when you have it connected? Also is it in Disk Mode? That might prevent it from charging quickly.
Ok, that's good to know. I guess I need to buy another usb plug for my office then that's rated at 1 amp. I have the Incredible hooked up at my home office today on the usb plug that came with the phone and it's gone from 29% to 33% in the last 25 minutes, which is faster than it was going at my other office with the Blackberry usb.
And I think i had it on disk mode for awhile too and the desk clock on. Didn't think that would affect the charge time as it didn't on my old Storm.
been using various BB chargers on mine since i bought it, no issues and it chargers much faster than you all are saying for BB chargers. Mine is like 3 hours max. You have to have other issues.
I use a BB branded usb cable at work. Does it make a difference if it's plugged into the laptop directly or my computer monitor? Because my computer monitor has 2 usb ports which is what I use.
neither takes that long, usb for PC or the wall pack charg under 3 hours generallyAre you using a BB charger or a BB branded USB cable? I'm referring to a usb cable. I looked at the specs of my wife's BB Storm charger last night and it outputs 700mah. Whereas the wall adapter that came with the DInc ouputs 1000mah (1 amp).
I agree that something else has to be going on with his phone but I just wanted to make it clear what type of charging we were talking about.
From memory, when I had an Eris for a few days, it had a special plug needed. Not micro nor mini usb. Had a wierd shape...
