Are you serious?
Restore the phone to factory condition (unrooted, no custom roms, no extra apps of any kind) and test. This is the only way to separate hardware problems from software bugs / user error.
i don't use any of google's crappy apps, and i'm not someone who uses widgets or anything. i'm more about functionality than looks so i've shut off everything. i've even used a black wallpaper but i guess that don't help with this screen. and i've already done factory reset before this. maybe the problem is the rooting? did unlocking bootloader and rooting somehow cause battery drain?
i might just have to go back to using a flip phone + ipod touch hahaha
You might not use them but they're still running in the background if you don't disable them.
dude' i've disabled them. i'm not dumb like that. you can check what's running in the background. i've check.
Yeah. I can tell that you've probably done everything to aid this problem but it won't go away, i'm thinking defective battery.
I have had a bad brand new battery before...it happens. The only thing that sucks with the N4 is you have to get the whole device replaced to fix it. I don't know what the situation is like at Google right now, but a couple of weeks ago they were maintaining stock exclusively for replacement, so it's possible that you may not have to wait more than a few shipping days.
This definitely isn't normal.
Like 6tr6tr already said, maybe factory reset the phone. However, it could just very well be the battery's fault - is there anyway you could try another battery?
If you do decide to go for a factory reset make sure you follow all the safety measures in order to not loose any important data. Here's a good article on how to ensure that: How to Reset an Android Phone
See "Android OS" and it's 23%? that's why your battery is dying quickly.
Things that poll in the background such as Currents, Pulse, Facebook, and other apps, will frequently wake the device up from sleep and request data(even with the screen off). I'd rather have it poll data when I open the app, vs doing it itself in the background. Especially since I may not open that app today.
I turned off almost all background tasks and my Android OS never hits above 5% and my battery easily all day.
He says he does that, I'm not sure what the difference between android OS and android system is though.
if by condition you me drain the battery then fully charge it then yes.....anyway i think those are just myths, i don't think it actually helps but i still did it anyway.
could it be something with android 4.2.1? a bug?
Conditioning a brand new Li-po battery is not a myth but is definitely required. Conditioning a battery is just using the device with the battery as you would normally plan to use it from 100% to 4% then doing a full charge. Conditioning take any where from 5-15 cycles after that period of time you can not condition the battery again it is set.
Battery "calibration" is a myth. There is nothing you can do mid-life span of a battery to reset it. All that can happen is resetting the indicator of the battery level shown on the device.
I also fly R/C Helicopters and they use Li-po batteries and I have dealt with 100s of them. Every single one has gone through there conditioning cycle. Most Li-po batteries will gain about 10%-20% after a proper conditioning.
If after the first 15 cycles you continue to experience this kind of life span return it.
like i said, i don't run any of that crap and i've shut off everything and made sure everything is shut down. from apps to services.
yanis
