AreaSlider v1.0[AreaRom] LG Optimus Slider
i did poss a rom was not mine but i ask for and got the okay you saw my act
anyway it doesnt matter now im not discussing this in the main forums its not gonna help you get unbanned so you might as well give up.
that fair can have you email adress if have any questions about rom
This is the type of person we should take the warning labels off of things, and let life sort it self out... Instead of banning him everywhere he goes, the police should show up at his door and take his computer away from him.. Or depending on what country he is in chop his fingers off.. I thought you were just annoying at first, but I have come to the understanding your just an idiot...
If it doesn't work I would make a partition on the SD card. I followed the instructions from jcole20's AreaROMQ forum.
It should work. It did for me.
yes it will deff work as the Q and the Slider are almost exactly the same only diff that i've seen so far is the keymapping.
Can we not get all those posts from that disagreement removed from this thread??? Its a lot of clutter in the way for people tryin to get actual help with this rom. Also, is anyone else having trouble with the wifi? Mine just says error when I try to enable it.
not really sure what would cause this but i was having the same issue on my precedent the other day.
simple reflash of the rom fixed it. =\
k just flashed it and the wifi doesn't work, reflashed it again and still doesn't just says error, tried both the settings and the power control panel
can this be flashed over any other rom?
I wouldn't flash it over a rom personally. The updater-script will format for you, but I highly recommend wiping data/factory resetting before flashing. To the people with wifi issues... like rook said just reflash if the problem continues let rookie know. Could be a bad kernel but that's a simple fix.
Ill upload a .zip later. Replace the boot.img in it and rezip it. (Use a boot.img from a rom you know has wifi working). This will (should) fix ur wifi problems.
(Basically you do this)...
The .zip I upload. Just unzip it to a directory on ur computer. Put a boot.img in it from a rom you know is working. Then (while in the main folder that will now house ur meta-inf and boot.img and all) highlight everything. Right click and go (hopefully ur using 7-zip) and create a .zip. put it on your sd card. Boot into recovery wipe cache and dalvik. Then install the new .zip from sd card. This should fix your issues.
Sent from my LGL55C using Tapatalk
off8485
