At "battery usage", how are Bluetooth and NFC displayed?
Aug 19, 2016
17
This weekend I made a test to see the impact of keeping Bluetooth and NFC always on (but I did not use them). As my use varies a lot (I can't keep only at "in the middle of the day my battery is always at x%, but now it is at y%"), I would use only the data displayed at "battery usage". I did not charge my phone up to 100% for three days, so the usage data would not reset. But, after this time (and during), when I opened "settings", entered "battery" and selected "battery usage" I could not find any Bluetooth or NFC indicator. I do not believe that those services simply did not consume any significant battery amount, so I think that they are displayed in common with other services (as "android system", "cell standby", "media server"... I don't know).
I do not have any power saving enabled, my settings are usually configured to prioritize usage and conectivity instead of battery (so nothing interfered with the test subjects).
Thanks!
If you open application manager, make sure system apps are showing, find the Bluetooth app and open it. Data and battery usage should be there...
Thanks, Tim!
I did this and found "Bluetooth MIDI Service", "BLuetooth Share" and "BluetoothTest", as well as "Nfc Service". In the BT case, I think the one I want is "BluetoothTest", since it's saying "2% used since last fully charged" (I have already recharged battery up to 100%, so...) and the others are just "none since device last fully charged". "Nfc Service" shows "0% used since last fully charged".
Oh, and I think Bluetooth is shown under "Android System" - I opened it and "BluetoothTest" is listed in the "Included packages". Not sure about NFC bacause it is not shown here, but I think it will appear here, too.
I'll redo the test and post it here.
Thank you.
So, after exactly 3 days, I got this:
Bluetooth MIDI Service - "none since device last fully charged";
Bluetooth Share - "none since device last fully charged";
BluetoothTest - "20% used since last fully charged" (6.67% per day, 0.28% per hour);
Nfc Service - "0% used since last fully charged".
It's important to note that I only kept Bluetooth and NFC enabled, but did not use them at any moment, so the shown usage is relative to keeping it enabled and nothing more.
EDIT: I can't say if those 20% was just for keeping BT on but without use, since I keep it enabled to improve location accuracy (Settings > Privacy and safety > Location > Improve accuracy > Bluetooth scanning). I have already disabled BT (before top charging, but kept "bluetooth scanning" enabled) and after 20h40m of a full charge, with 54% battery remaining, "BluetoothTest" is reporting "4% used since last fully charged". So probably some amount was being used by location services, not only to keep BT active.
It's also important to note that the "20%" Bluetooth test is 20% of the total consumed. Unless you're draining the battery to 0% (I can give you a link to a new battery if you intend to do that regularly - meaning for about a month, until the battery fails), that's not 20% of the battery.
cinemacritic
