AT&T. 4.3 update passed AT&T certification today.
Downloading as we speak from Puerto Rico.
Had to change the date on the phone since I had to wait 8 more hours to check for update.
Updated in GA no problem. Was kinda hoping for the new shiny feeling.
I think I'll wait till all the dust clears
Sent from my One using AC Forums mobile app
Updated with no issues so far, but still have apps with the dreaded black bar.
There is a setting that you need to change to get rid of the menu bar. It's under the display section I think (my One is in the other room on the charger at the moment), but you need to change the home button behavior to swipe up for Google Now and hold home for menu, then the black bar will be gone.
Thank you for that info! Got it!
Settings>Display, gestures & buttons>Buttons>home>select Swipe up for Google Now, press and Hold for menu
Mines stuck on 7%
Make sure you have a good wifi connection. Also keep your screen on. If the screen turns off wifi my disconnect.
Sent from my HTC One using AC Forums mobile app
Upgrade went fine. No issues so far, but haven't done much. Need to charge now before I take off for the Sharks game.
vinod681
