AT&T And TMOBILE June patch
in case of ATT, the file end in TMB, is save put it in Note 9 ATT, this action convert to TMB or is the same fw for boths only Fw file has named XXX_TMB? Please Help me
The firmware file is same for all the carriers
If your phone is sim unlocked, and you load your TMobile sim into your Att Note , you'll get the TMobile splash screen booting up and carrier apps and setting
I live in costa rica and never receive OTA updates for my note 9 ATT, can i put directly the tmobile fw for convert it and receive OTA updates regulary?
Yes you can
Which security patch your on right now , some Att version got stuck on updating but then were fine after. Your on Android 9?
Yes you can
Yes android 9 but security patch january, put this fw via odin, i find this like ATT fw , not remenber if in this site or another one, i'm not know much and temerous of damage my dear Note 9
Yes you can
Just use the files above in Odin and you should be good to go
Fw you recomend me, is Verizon, is this OK? My God i'm so scared!!
All firmwares for Carriers are universal works on all your simcard will provide the bloatwares for the carrier you are on so doesn't matter if you flash Verizon or any other firmware from carriers.
SaakalSEO
