AT&T data plan for galaxy nexus
I just ordered a galaxy nexus from the play store last night. I have an iPhone 4 with grandfathered unlimited data plan. I asked an att employee if I got a new unlocked phone if I would keep my unlimited data plan. She said everything I have on my plan would stay the same but that I would need a new sim card. But I'm reading on here that I can just put the sim from my ip4 into the nexus and should have no problem. Do I have it right?
That is correct. You may need a sim adapter for it though. The sim on the iPhone is a micro-sim, and the sim for the nexus is not.
Reactions: dcjose48
Probably their way of getting you to spend more money in their store.
Outside of an adapter, because, like the guy in front of me said, the iPhone uses a micro-SIM card, you don't need anything more. Just plug the old SIM card into the new phone and you're good to go.
Adapters are like $0.50 on Amazon.
Reactions: dcjose48
OK thanks for both your answers. I'm going to buy an adapter from amazon. Is there any specific one I should get? Ive seen some that say for iPad so I'm just wondering if it matters.
I didn't want to start a new thread since my question relates to this topic so hopefully someone can help.
Currently I have an unlimited iPhone data plan using a 4S on AT&T. I ordered the GSM Galaxy Nexus from the Google play store yesterday. What unlimited data plan is available for the Nexus on AT&T? Or can I just keep using the same data plan as I am with my 4S?
Thanks in advance. :)
Just put the SIM from the iPhone into the Nexus and it will work. You don't even need an adapter. Just get it lined up correctly and the tray has a tight enough fit it doesn't move.
I bought a cheap one on Amazon and nearly ruined my phone's SIM tray trying to get it out.
I HIGHLY recommend www.microsim-shop.com. I have one from them and it works BEAUTIFULLY. No stickers or anything, your microsim snaps firmly into the adapter with no chance of catching as you pull it out. It's a bit pricier than the bottom-rung Amazon options, but well worth it.
Sent from my Nexus One using Tapatalk 2
Ishimwe
