[AT&T] Galaxy Note 2 baseband unknown
I have many radios available, I tried flashing stock radio from rogers my service provider. When I flash using recovery mode it completes the process but still after the boot my service is not back and in settings menu baseband version is unknown.
I have a similar problem with my note 2 and I think it is the partition tables messed up but I cant find a pit file for the Att model to fix it
Why are you flashing everything with odin. Odin flashes the root file only. Everything else flashes with TWRP or CWM. I recommend TWRP.
Also it kinda sounds to me like you flashed an att mod or rom to a rogers device.
Sent via Tapatalk
Sent via Tapatalk
Can you direct us to a recovery flashable version. Because I can only find zips that contain only modem.bin
Also do you mean rogers onto AT&T.
From my Galaxy Note 2 via Tapatalk
No. He says rogers is his provider. They have a different model number than att. The roms and mods are not hackwards combatible afaik. His problems most likely stem from flashing a mod not meant for his carrier.
Sent via Tapatalk
Sent via Tapatalk
He started this thread and it says AT&T in the title. So now I'm confused. I think he meant he has att and tried to flash rogers.
I dont think he knows what he has. He said att in the title but mentioned 317m as the model. Att sells the 317 not 317m. I know because I have att.
Sent via Tapatalk
Hey droid I have same problem with my note and also even if I put the stock rom on there I still cant get service I think it has something to do with my radio or kernel or something. Thanks
My Note 2 N7100 IMEI suddenly become Null/Null.
Baseband Unknown
I did not root my device before that happened and only rooted it after surfing the internet and many advice to gain root access and fix this problem.
Issue is, I'm totally new to this root thingy and still lost on finding my correct direction.
Appreciate if anyone could help me on this.
You need to download and flash the correct modem for your note 2. What is your carrier? and in Settings/About Device/ What is your baseband version?
hi can i get different link this one is not working
Thats because it no longer the correct file. You are reading about a file that has been updated 4 or so times. This thread is almost a year old.
Sent from my SAMSUNG-SGH-I317 using Tapatalk
Did you ever get this fixed for this person? I have the same exact issue. Any help would be appreciated.
I am using GT-N7100 International model... Had the same issue after I installed stock rom downloaded from interenet. Installing modem bin sorted out my issue (it was GT-N7100 Modem.bin zip file, what I installed using CWM). After I restarted my phone, it picked up correct IMEI, and my GSM services (phone calls, SMS, 3G) started working
hiredbyskill
