AT&T Nougat!
Status
Not open for further replies.
Did you folks get any new wallpapers with Nougat?
I thought we might but I can't seem to find them :confused:
Battery drain was heavy the first hour or two after the upgrade, but seems to be leveling off in a more normal pattern. I think it will take a day or two before it settles down and useful data is available.
Aagh !!
The settings menu was changed.
Just when I thought I had it figured out & could do it in my sleep
Aagh !!
Yeah I dislike that they took away the quick setting options, but after you get used to the way the new menu is it seems easier to find stuff.
Just checked and it's downloading now! I've been checking everyday for the past couple of months now, I'm glad it's finally here!
The phone defaulted to FHD . Did you leave it there or returned it to WQHD. I haven't had it long enough to determine the difference if any in battery life.
Can't wait till Samsung updates Good Lock for nougat so we can customize the colors of notifications. Also, the only thing that bothers me about nougat is it seems the battery save mode has to either be on(medium or max) or off and can't be set to just come on at 15%.
Re: AT&T Nougat!
You have to Odin back to stock MM APK1
Thanks, that's what I was afraid of. Flashing back to a stock ROM is beyond my Android technical skill set.
Edit: I found good instructions on XDA and I'm all set
Status
deevencoo5
