AT&T Software Update For Note 5
You can always manually change the date/time if you want to force it. I've done that numerous times in the past to force check/update my Note 3.
I meant I had to wait because when I saw this thread on AC I was on break at work haha Does time affect when the update automatically shows up? Im eastern time btw
Looks like it fixed the wireless charging problem. I laid my phone down with no adjusting and it charged to 100%.
Posted from my Note 5 via the Android Central App
I read on several other forums that the update was for the wireless charging system.
Posted via the Android Central App using the AT&T Note 5, 64GB
Is anyone using the Note 5 on Cricket able to get the update?
Sent from my SAMSUNG-SM-N920A using Tapatalk
I am getting better lte and wifi signals at my work since the update. Don't know if this was part of it or not but thankful for the better performance
Posted from my AT&T 64 gig black Galaxy Note 5
My update started right as I got home. I guess it wanted to be on WIFI to do so. Over the next few days, we'll see how the device operates...
I notice a decrease in battery life since the update. Went from 100% to 85% this morning when previously with same usage I would be at over 90%.
Agree. I am seeing decreased battery life as well.
I am too. I disabled a lot of packages from Package Disabler Pro using the basic xml list, and last night it was draining very slowly, which was a good thing.
The jury's still out on what this update actually fixed. Like others, I had a successful wireless charge on the Samsung bundled charger last night, which was the second one in 8 days of having the phone. I put it back on the pad just before my morning shower to top it off and when I got out the light on the charger was flashing blue once again...
Regarding the degradation in battery life, is there as easy way to revert to the pre-update version ?
AH...I see now. You'd want to force it because ATT prevents you from trying to update multiple times a day if it doesn't initially find any updates. It says something to the effect of "try again in 24 hours" and that's what I thought you meant was preventing you. Manually setting the date/time circumvents this.
Installed this upgrade yesterday afternoon. Don't notice any difference to any settings or performance however, I wasn't having any issues to begin with.
The prompt did state it was regular "maintenance" though.
racoo
