For those that have been using FoxFi (and it works) and just hitting the home button when you get the "To enable mobile hotspot on this device, go to att.com/mywireless or dial 611". If you have updated to Kit Kat, does that still work?
According to this thread: http://forums.androidcentral.com/samsung-galaxy-note-3/320812-foxfi-note-3-a.html, users are reporting that home button still works. Hopefully that's still the case if you plan on getting the device or if an update has caused problems.For those that have been using FoxFi (and it works) and just hitting the home button when you get the "To enable mobile hotspot on this device, go to att.com/mywireless or dial 611". If you have updated to Kit Kat, does that still work?
I know it works with 4.3. From the looks at other threads there is a Kit Kat update out there somewhere. If there is, I don't want to take it if it causes FoxFi to not work.
I didn't realize this would work but fox fi works perfectly after I changed to shared data plan.
Sent from my SAMSUNG-SM-N900A using Tapatalk
FoxFi stopped working for me after upgrading to 4.4.3. Pressing the home button no longer works.
Any one else having this issue? Any ideas?
