Audio issues
Xanth269
511
26
Ok so i got an issue I hope you can help out with. using AOKP b38 and Franco r196
over the past couple of weeks there are times when I get a phone call, and the person is very low almost to where I can not here them. I check and the volume is cranked, I also use audio manger. it could be the same caller and some times its great and sometimes it suxs.
So should I try a new ROM or might it me the kernel?
any direction would be helpful.
Thanks,
Xanth--
winka9x9
