Audiogalaxy skipping problem
primebeatz
Active member
Dec 8, 2010
30
4
Music plays fine for about 30 seconds, then starts to stutter and skip nonstop. If I pause for a while, then resume, it will play fine for about 30 seconds, then the stuttering begins again. Uninstalled and reinstalled the program on PC and the app on my Epic and still no luck. No help to be found on the Audiogalaxy website either. Any suggestions?
Sounds like it's trying to buffer. It may have a 30s buffer in the program, so when you pause it, it fills, plays for 30 and runs out of data. Does it only do it on 3g or wifi too?
It looks like it pulls the music directly from your computer. A LOT of internet connections have a very slow upload speed (from your computer to the internet) even if you have say a 10mbps connection, you may only have 128k or 256k up, and if anything else is going on, that may not be enough data to keep playing...
I was thinking it was buffering too. It happens on 3g, 4g, and Wifi. Used to run smoothly. So youre thinking it may be a problem with a program on my PC hogging the resources? Havent installed anything new. Nothing seems to be bogging down my device so it mat be my PC. I will have to try later.
RichardDixon
