auto disable/enable wifi/data connection on Galaxy Note 2
sonyscaria
22
Is there any option to auto disable/enable wifi/data connection on Galaxy Note 2 ? I just dont want to run data while at sleep. I am looking for built in option that third party applications
I do not believe that there are any built in options that will auto turn on/off WiFi/data service built into your device. I know you can use the toggles up top easy enough but aside from that I do not believe that there is any on-board options. You may need to download something like Tasker.
heritagevine15
