Auto Rotate does not work.
Have had that problem for almost 3 months. Found a quick fix for the issue. If you power off your n7 and press hard on the back around the "n" and "s" on the nexus logo, it will put the connector inside the tablet and the screen will rotate again. Unfortunately, this is only a short term solution and may require you to do so over and over again. I googled and found a complete fix on YouTube. This fix will permanently work, however it will require you to tale the back off your tablet. Here is the video:
Nexus 7 2013 Auto Rotation Freeze(easy hw fix) - YouTube
I did this last Friday and it's still working!
J
Mine started after lollipop update, would rotate after a lag and then stayed in portrait. But I read a post above and went into accessibility setting unticked auto rotate, rebooted and waited like 5 minutes. Went back to accessibility settings and ticked the auto rotate and now it works again!!! THANKS Isaac from post #20!!!!!!
Same problem with a Droid Razr M. Found an widget called would you guess? " autorotate on/off " by Curvefish in the playstore with about 5 stars. It works for me. Thanks Curvefish.
I am not sure you will like my answer
but the only things that solve it was to hold the tablet in both hands and band it a bit
just a bit, dont break anything
it immediately released the accelerometer sensor
Hope it helps,
I think the suggestion I gave above is a bit safer than bending the tablet. This is definitely a permanent solution.
J
I've had my N7 from Day 1 and have never had this problem --- until a couple days ago. I restart it and that fixes it. I thought it may be a 5.1.1 issue, looks like it may be something else.
I've noticed the same behavior on my N7 since upgrading to Lollipop. I've seen the hardware fix video on YouTube and was about to try that when I came across this thread. I'll try the fix recommended by eclein before opening it up.
Sent from my Nexus 6 using Tapatalk
had the same Problem, i notice a way to get it to work. its when you switch on your camera you will notice the screen rotates
Inside the Nexus 7 2013 are two FPC/FFC ribbon cables that bridge over the battery that can become intermittent when loose. Search on YouTube for drHerrscher. He has several videos.
I had given up and installed Set Orientation and then saw this thread. Just for grins I force stopped Set Orientation and turned on my camera. It didn't auto rotate. I powered it off and then back on again and it now auto rotates.
It was too good to be true. The next time I opened the case my N7 refused to auto rotate. Back to Set Orientation.
I have another problem. On the YouTube app, whenever I view the 60FPS option, it just freezes, It never did this before untill recently.
I remember this happening last time we had a major update. My goggle now launches randomly now. Just like last time. Maybe or maybe not
my device will not auto rotate if the device is a bit warm (or overheat). Overheat usually happen when I play a particular intense game OR when I use the device while on charging (charging tend to keep the device warm beyond normal temp).
The only way to fix is to restart the device.
Anyone experience this?
Nexus 9 Tablet Auto Rotation Fix
Try the following link: it works!
https://www.youtube.com/watch?v=CbGi0yohfMA
Details:
Check first that "Auto-rotate" is turned "on", and does NOT work. Then:
1. Go the apps screen
2. Open up: Google
3. Got settings: top left three bars, the "settings"
4. Select Now Cards
5. Under Show Cards: De-select (turn off "Show Cards")
6. Turn off Nexus 7, and Restart.
7. Make sure "Auto-rotate" is turned on.
8. Auto-rotation will work again! (on most Nexus 7 tablets?, if it still does not work, "uninstall" Google Now all
together, and reboot. If you re-install Google Now later, and set it up, and reboot,"Auto-rotate will still work)
9. No need to tinker with the hardware, and open the tablet!
10. Spread the word.
Technical details:
When Autorotate does not work:
All my tablets are running Android version 6.0.1.
Kernel build: 3.4.0-g09a22c6
android-build@wpdv14.hot.corp.google.com #1
Wed Apr 20 00:06:25 UTC 2016
Build Number: MOB30M
1. Download and install: Check My Android.
2. Open the App
3. Select: "Sensor"
4, You will see that the following sensors are disabled, or do not work:
1. MPL Accelerometer
5. MPL Gyroscope
7. MPL Gyroscope
5. Turn off the "Now" cards in Google, as above
6. "Auto-rotate will work again.
7. Sensors 1, 5, and 7. will work again.
8. Interesting note:
If you turn on the "Now" cards again, in Google. Power down the tablet and resart. The "Auto-rotate" keeps on
working (ONLY ON SOME NEXUS 7 TABLETS (I have 5 of them, some work, some not)), and all sensors show OK? For now at
least!!! No idea why??
To play it safe, just turn of the "Now" cards, (or uninstall Google Now), and reboot!!
Peter
20 June 2016
MichaelCrusan
