Automatic Deodex/Odex Method Released - via 928droid
it doesn't matter which it is, it will only alter /system, there's no kernel or boot image with it.
Stupid question how do I boot into recovery?
Sent from my DROID X using my fingers!
go into the bootstrap app and press the "bootstrap recovery" button. after a second, a pop-up will appear that says "success!". after that, you can hit "reboot recovery" or go into clockwork recovery (with rom manager) without an issue. the key is, you have to run the bootstrap app first, otherwise you will just get stuck on the M
If Im running their theme, can I put another status bar on top of it or i have to take the theme off. I like the theme but not to crazy about SB, not matching with what Im trying to do on my screen.
TIA!
^ I don't see why you couldn't add a different status bar on top of it.
What theme are you running now? I like the Word Icons and the camera in status bar.
I really like the 928 Black Glass, but it's the first theme I've ran.
TIA!
I've used different task bars with different themes as long as you're deodexed, you're all good. Just backup first just in case though.
Just FYI, the camera in the status bar is the screenshot app, drocap2.
Also, the word icons aren't in that theme, I believe. I don't even know of any themes that have word icons. Those have to be done manually.
928Droid Bgx 2.3 Theme
Just so wondering if any one is running it? It deox. Your system it themes it. It is very simple and sharp.
http://www.928droid.com/
Merged.
I downloaded the "Back To Stock" deodexed and odexed just as backups if I need them and don't want to flash the sbf but I'm not a fan of the theme that much.
thanks but maybe adding 928Droid to his title would help. i would have never thought of looking here for that.
Merged.
Thanks for this post, its a nice find... Love the theme.
rvrsco
