Aux Cord broke inside headphone jack HELP!!!!
Mschw006
19
This is my first post on this forum. Hello Everyone!
So my Aux cord broke off inside of my headphone jack and I can't get it out. Ive tried ubreakifix and they cant do anything. The headphone jack has no opening on the end of it to push anything out when you open the case. Is there anything else I can do? Ive tried the spring thing and that didn't work either. Im lost here. I cant listen to music through Bluetooth or make phone calls without using speaker phone because the phone thinks there's headphones plugged in. Is their anything else other than doing warranty because I don't have the $200 to replace it.
Thanks!
Just gonna ask something. Is it possible to disable the headphone jack through rooting the phone or by disabling a file?
Try a tiny spot of super glue on the piece in the phone, then poke it with a thick paperclip or thin piece of coat hanger. Make sure you let it dry all the way before you try to pull it out.
Sent from my SAMSUNG-SGH-I747 using Android Central Forums
Wish I would I would have a seen that when my son had that happen to his ipod. I cracked the screen trying to fix it.
If superglue doesn't work epoxy like jb weld will. You'll have to ensure a good connection while it dries regardless of method.
Ill give this a shot. the super glue didnt work. I figured out a way around it so that it doesnt think theirs anything in there. as long as i make a Bluetooth call and my phone doesnt turn off then it works
RichardDixon
