Baffling lack of sound
jenkkijason
3
Hi, seems a simple problem I should be able to fix in settings, but when I use the timer it does not make any ringing or buzzing sound when the timer expires.
Thanks!
Welcome to Android Central!
On my S4 when I go to timer-->Settings there's an option for the alarm tone and the volume. Do you have a tone set and have the volume set a level that you could hear it?
Hi Halcyon, thanks for the reply. I'm still a little confused though, I don't seem to have an app called "Timer" only one called "Clock" and it has no way to access settings that I am able to find.
Ashok Dharshan
