Bar code scanner
Hi
ShopSavvy is working very good and I have used it many times. I have also barcode scanner too but i am using both because shopsavvy is easy to use.
Thanks
Lisa
I downloaded barcode scanner, but have yet to use it. Sounds like shopsavvy is a good one too. I'll have to check it out.
Thanks everyone!
I got one that had the camera and I guess you put the bar code in the line, but it never did anything but stare at the barcode.
Make sure that lighting is good and that you're holding it steady and that the barcode is within the box. You'll probably get better results if the barcode fills as much of the box as possible.
leilani
