Battery Capacity
croth56
3
Has anyone installed the Accubattery app ? I have a Note 20 ultra. It's supposed to have a 4500mah battery. Accubattery reports 4370mah as design capacity. Before you say the app is not accurate, read the portion about your battery under " Settings - About -battery information" . Sounds like Samsung is saying typical capacity is 4500 but it could be the minimum of 4370
What are others seeing ?
Thanks
Thanks
I use it, but I have no battery capacity info under Settings ---> About. My only options there are Recent changes, About: translations, Submit diagnostics, and Build version.
In the Health section (link at bottom of app) mine shows this:
Battery health - 93%
Estimated capacity - 4,062 mAh
Design capacity - 4,370mAh
Based on 3 sessions with 121% charged for 4,915.
I've had my phone for 2 days and I charged to 100% on the first day, and only to 80% since then.
4370 is a rated minimum, 4500 an average tested or along those lines, it's nothing to worry about
Life is too short to worry about the small stuff enjoy your new note and only worry about the big stuff! I could understand a major glitch in the phone otherwise I would let it go!
Thanks
No. This app is terrible and strains your battery. Battery apps are the worst thing you can install.
Misinformed post.
Task killing apps drain your battery.
Accubattery does not drain your battery.
As for me and my S20.
Samsung rating: 4000 mAh
Design capacity: 3880 mAh
Esitmated capacity: 3652 mAh
lluigidagg
