Battery case & Wireless charging
Keron Young
I currently have the samsung s6 edge with a power case attached to it. And I was told that the wireless charge on this phone works though all cases, so I bought a magic disk II wireless charger pad. But it did not work though my case. So I was wondering if there was a pad that would work with my case?
Wireless changing won't work with a power we case.
I have a Ringke case (which is really thin) and an Obliq case. wireless charger works for me.
Here's the problem. Android phones across many manufacturers have the same issue. It's actually the Qi technology. Go to your settings and turn the daydream on. After turning your daydream, turn or select the maximum amount of time that your screen may stay on. Place your phone on the pad and it will work.
