Battery case with built-in microSD card reader?
Gaurav
Active member
Jun 26, 2011
26
Man this would be my ideal accessory if some one out there would be interested in making it! Basically my wish is for a battery case like various options that exist for other devices but also with an integrated microSD slot. I imagine something that combines the sleekness of the powerskin sled but also has a ability to read microsd or minusb like the kickstarter link below:
Nexus 5 battery case - Page 2 - xda-developers
Mini MicroSD Reader for Android Smartphones & Tablets by Andy & Rich — Kickstarter
Anyone else interested in something like this?
So while it might work fine you would need a switch or install a custom kernel.
Normally when USB-OTG is active, the phone won't charge.
On the Nexus 7 you had to run a custom kernel after unlocking the kernel to charge and have the USB-OTG function at the same time.
It is possible to have a switch to chose which function.
You only need to remember to unmount the memory before selecting the switch.
Could integrate an nfc chip that launches a dedicated app that automatically switches it when done using the card.
lostcowboy
