Battery case
Ah okay yeah doesn't seem like a lot of people know about it, but it's a wireless car dock so instead of having to plug the phone in when you get in your car you can just put it on the dock and it'll charge as well as provide an easier place to keep your phone while driving, if you do end up trying it make sure to go with the nexus 6 specific dock
I think the best solution for me is going to be the quick charge 2.0 car charger from Amazon. Thanks for the thought though.
Sent from my Nexus 6 using Tapatalk
Are there any quick charge 2.0 car chargers off of Amazon that you would recommend?
No problem figured I would suggest it, as for car chargers I use an older model of thisAmazon.com: Anker PowerDrive 2 (24W / 4.8A 2-Port USB Car Charger) iPhone Car Charger for iPhone 6s / 6 / 6 Plus, iPad Air 2 / mini 3, Galaxy S6 / S6 Edge / Edge+, Note 5 and More - Retail Packaging - Black: Cell Phones & Accessoriesit's not quick charge but it charges pretty fast from my experience and I need the 2 usb ports, if you only need 1 port though the Anker Powerdrive+1 would probably be a good option, it's pretty cheap and has quick charge 2.0
Okay thanks I just ordered a turbo car charger from Amazon for $20 it has dual USB outlet so hopefully it'll work fine if not I'll return it and get another one. Thanks again.
No problem hope it works out well for you.
cp0629
