battery charging questions
dubge
1,106
42
So when charging the lock screen gives you the % and when it is charged it says charged, but if you go into the phone while still plugged in the battery icon in the top right corner still has the lightning bolt like it is still charging, also if you go into the battery stats while plugged in it says 100% charging.
Question is will these ever say charged or not show the lightning bolt when plugged in?
When plugged in the lightening bolt is always there.
Also when mine is totally charged it shows charged
I use battery indicator to show my battery as a percentage but it displays it on the left.
RockoAndroid3689
