Battery conditioning question
adamtalife
235
21
So after I run my battery down to 0 and it shuts off, do I keep it off for the night until it's fully charged or is it ok to turn it on when it's ready to be turned back on?
Sent from my HTC One X using Android Central Forums
There really is no battery conditioning anymore with lithium batteries. But I would leave it off until it's fully charged and then turn it back on. I believe that you can still bump charge.
via Razr MAXX
Bump charging is also bad for the battery. This causes the battery to overcharge by a small amount by pushing extra voltage into it (not a very good explanation, but it works).
Lithium Ion/Polymer batteries operate most efficient when they are not ran all the way down. you can actually wear your battery out faster by letting it drain until it's completely empty.
sonmaria6
