Battery differences
Porkchopexpress1969
208
3
18
Does any know what the difference is between eb-bn910bbu and eb-bn910bbe? My phone came with the eb-bn910bbu. But all I can find is eb-bn910bbe.
Thank you
PCE
I don't know the difference but back in May, I bought two of the batteries ending in u on eBay for $9.99 each. They are OEM batteries just like the ones the phone came with and last just as long each charge.
The battery I bought on sale from androidcentral a few weeks ago was the bbe version and I don't notice any difference in use between it and the battery that came with my Note 4. Actually, from all of the threads in this forum describing problems with the original battery, I would be happy that Samsung had made a change in the battery resulting in a different product number.
Larry
I have been looking for eb-bn910bbu and only finding eb-bn910bbe. Not sure what the difference is. I was reading not to buy from ebay as much, because there is a lot of counterfeit batteries out there
I posted a thread on here back in May about the $9.99 batteries that I bought. They are identical in every way as the ones that the N4 shipped with. I am using them now and can't tell the difference except that they last longer now then my originals that were wearing out.
I got five hours screen time yesterday which I could never do on the originals. I highly recommend them.
I also bought two for my Note Edge.
Do you remember who the ebay seller was?
BBE: cell made in Japan, assembled in China.
BBU cell made in Korea, assembled in Vietnam.
The batteries above are NOT OEM batteries. Someone brought that to my attention. I do not recommend buying those. Sorry for any trouble.
There is no difference. The the last letter stands for which market the battery was intended. So e stands for Europe, a stand for Americas, u is for Asia. I purchase my batteries directly out of Asia where they are manufactured, bypassing American wholesalers, to get the freshest, newest batteries. So, I am less concerned with which market the battery is intended for, and more concerned with getting the latest manufacturing run.
koltyn
