Battery Drain After 4.2 Update
circleinsideabox
51
Is it just me? and my phone is charging SUPER SLOWLY. Also, the same thing is happening with my Nexus 7.....
I hope I am not alone in this matter......
I am having serious battery drain issues. Mine is coming from "Exchange Services". Called Google Play tech support this morning and they know about the issue but don't have a solution as of yet.
thank you for responding and
thanks for the update from Google ( I wanted to call but I didn't have the time today)
I can confirm that I was able to resolve my issue by performing a factory reset of my phone. Microsoft Exchange no longer
drains my battery. Everything is normal now!
Same issue on my end. Google support also said to reset the device, but interestingly also said that would roll back the device to 4.1.2 and not 4.2 At that point I lost all confidence. Nice to see you have it working. I'll test it this weekend.
I got the Galaxy Nexus HSPA+ version. just got the OTA update to 4.2 about 6 hours ago. Since then, by battery has drained two times already. Haven't really done anything with the phone. Anyone else have this problem?
Some others have reported that. The solution so far it seems has been to just factory reset the device.
Alternatively I deleted the account and then recreated the account. This has resolved the problem as well.
I suspect that the issue is caused because of the "security administrator" configuration. Before I deleted my exchange account and recreated it I could actually add widgets to the lock screen. However after the account was recreated the additional lock screen panels were quickly disabled. I suspect this had something to do with the additional battery drain. This issue may only surface if your exchange administrator has pushed additional security admin configurations
thanks
anand
I had to factory restore (that's how I got 4.2) and right after the update my battery life was ****. Now, 3 days later, it's improving with every charge cycle.
I had the same issue, but not immediately after the JB update (haven't received 4.2 update yet through US Cellular). Exchange was working overtime and seemed to be continually draining my battery over the past 2-3 days. I researched and couldn't find a solution. I tried to remove and restore the Exchange account and that worked for a while. I'm rooted and tried to freeze some programs via TB and see if that helped but to no avail. Finally I picked up on a post that mentioned attachments potentially being a problem. Immediately I remembered I had an email with a 14mb attachment that I hadn't deleted. There was also another email with 7 attachments of 1+ mb each. I removed both of those emails from my inbox and filed them and that seems to have solved the problem. Since I did that the battery life is back to normal. I hope this helps.
I have been getting a lot of battery drain as well, I am at about 8-10hrs of basically standby time per full charge. This all started around December from what I remember. I have noticed that a lot of battery drain came from Google Plus, Google Maps and occasionally Facebook. I have the GSM unlocked nexus and I am very frustrated by it at the moment, because it feels like I can't really use the phone without it being completely drained in a few hours. I have done some testing and it seems related to my phones radios. In airplane mode I get 20+ hrs of battery life, which still seems a bit low, but even with wifi I get this significant battery drain. I am using AT&T for my provider.
If I do a factory reset I lose all of my data stored in my apps correct? Also you think this will help?
I turned off GPS/location and get better battery life. From 7-8 hours to about 15-16. I love Google Now but it's a serious battery drainer.
I had the same problem - after upgrading, the phone stayed really warm, batter drained every 3 hours without doing much at all.
Thanks for the info everyone provided here. Did not want to reset the device. So I tried by un-installing Outlook Email and re-installed it back. The problem is resolved. Now the phone temporary is back to normal, battery time is back to prior upgrade as well.
Joltpost
