Battery drain, complete, overnight.
May 25, 2015
7
I recently put a new hi-cap battery in my s4 active and found it completely drained and turned off in the morning. I then put another "new" hi-cap battery in and this is what I found this morning. I have had these batteries before with no problems. Does anyone have any ideas. This phone is at least 4 yrs. old.Screenshot_2015-09-21-10-09-15.jpg
4 year old phone? S4 Active came out in 2013.
I have the same phone and had been experiencing bad battery issues for at least 2-3 updates. I finally decided to do a factory reset and my battery problems have dissapeared! Wish I would've decided to do the wipe sooner!
P.S. Uninstall that dictionary app! ;)
Yes, it seemed like I had it longer than that, but you're right, just a couple years old. I don't know what it was with the battery. I probably didn't close the app and the batteries are fine. I updated to 5.0.1 lollipop and have very good battery life.
kingteekay
