Battery drain no Dozing on home G wifi
danielcj
236
So I noticed my 5x doesn't doze on WiFi at home but does on WiFi at work. My router is several years old and is only G no N or AC. Anyone with older routers also noticing this. I would think that with Marshmallow it should be backwards compatible.
Weird. I wouldn't think that the phone would care what type of connection so long as it was connected to WiFi.
Sure you don't have any other location based services set up?
Location services are the same whether I'm at home or work so that shouldn't be a problem. I just don't get the same flat line that I see when doze kicks in. It's a steady decline at home.
I would test in Safe Mode while at home to see if it is an app issue.
Pettywife
