Battery drain since 4.1.1
CTalman
177
Has anyone noticed faster battery drain since the most recent 4.1.1 update (OnePlus 3)?
I cleared the cache after the update but I'm definitely seeing quicker battery drain....A friend who has the 3T said he is experiencing a similar thing...
Anyone else?
Thanks.
When did you update?
I did notice heavy drain on my 3 for a few days after the update, but it balanced out within a week or so.
My battery is definitely not as good as when I first got it, but I mostly put that down to almost a year of wear.
Updated almost a week ago i think. I'll keep an eye on it and see if it balances out.
Thanks.
Curious if you all got the update via VPN from Canada or Germany - I am in the US and have not gotten notice of available update, even after manually checking (like apparently everyone else in the US) - 3T here.
I noticed this too. Also been having problems with the back button.
Just updated to 4.1.3, so maybe that'll fix the issues.
It did seem to settle down a bit after a week or so but was certainly not as good before the update.
Also now on 4.1.3 so hopefully battery will improve....
Getting, overall, good reports on battery life on OxygenOS 4.1.3, particularly after a cache partition wipe after updating.
No difference in battery life seen here on a OP3 using either the 0324 (or was that 0328?) or 0411 builds.
boone
