Battery drain with Quick Circle case
G4userPoland
Hi all,
I have bought a new LG G4 phone last week on sunday, and noticed that when using the Quick Circle case (with wireless charging option) my phone suffers from battery drain when the phone is on "stand-by" laying on my desk.
When i use the quick circle case, my battery seems to drain around 5 to 7 % while being on stand-by just laying on the desk with screen off.
When i use my normal case that i got with the phone itself the battery drains only 1 to 2% while laying on the desk stand-by with screen off.
So for some reason the quick circle case is draining my battery, is anyone familiar with this issue or have experienced this yourself? Is this is known issue and is there a way to solve this? At this moment i feel like i wasted money on the quick circle case, because it's not worth to use it with the huge battery loss.
I also noticed that when i'm using the Quick Circle case i can see that "google services" are using much more battery usage than with the regular case.
thank you
Hi, thanks for your reply.
I'm not using any apps at the time of battery drain. The battery drains quicker on stand-by mode when the quick circle case is equipped on the phone. When i equip the normal case i got from LG the battery consumption is way lower on stand-by mode. I'm using the phone the same way with both cases
NameRingtone
