Battery Drain ?
May 18, 2014
11
Hello,
What is the average battery drain of your phone when not using it...
For example i unpluged it this morning, checked my emails for 10sec, put it in my pocket, went to work some network loss ( bad reception at work) but i only turned on the screen to check notification.... now after 5h10min its about 85%....
Is it a normal drain ?
Hello,
Sounds pretty decent at this rate your phone will last total of 30 hours... (or 25 more hrs) If you continue the similar usage
shronlndry
