Battery Drain
Nigel Huang
21
Hello, I'm running Android 4.4.4 on Nexus 5 and I have Battery Doctor, Cut the rope, Piano Tiles, Paper Camara, and Swiss Army Knife installed. When I got the phone I'v been having serious battery problems. Apparently Google Services is using 78% of the battery. Location services is on device only. I just finished charging to 100% and when I unplug 1 minute later it loses 2%. Please help me fix..
Can you post a screen shot of the battery usage screen when the battery drops below 50%? Also provide the screen on time screen shot so we can see what's happening.
You may need to factory reset them add applications back slowly to identify the problem. First, let's see if we can identify the culprit :-).
Many phones report 100% charge when the battery itself hasn't fully charged (due to the method of measuring charge state and the fact that the charger is adding voltage to the measurement) and as soon as you disconnect the battery it reports almost, but not quite, fully charged. When that happens, plug the charger back in for an hour or so. Eventually, the charge state will recalibrate (unless the phone is defective - they you'll never get more than 98% charge).
