battery drains after charging
opallo
4
Hi,
I'm wondering if someone had the same problem. I'm using Asus Zenfone 2 Laser, android 5.0.2.
After charging, the battery drains quickly and there's much more RAM used than normally. After restarting the device everything works fine and the battery lasts at least for two days. This happens every time I charge the device.
I don't need to tell that restarting phone after every charging is pretty annoying :)
Thanks for every answers.
If you let it drain for a bit before rebooting, what do your battery usage stats indicate as the cause?
I've got the same apps that after charging (zenui launcher, mail, chrome, splendid, clock and google services).
Maybe there's some memory leak? that would explain why the issue is gone after rebooting.
shahindaosama22
