Battery Efficiency/Charging Cradle?
Bowa11
Active member
Sep 8, 2010
37
Does anyone know if the battery will be effected if I left the phone in the desktop cradle for probably an 8-hour work day while I use it for music/internet/etc?
I am trying to get an answer if it actually does damage/shorten the life of the battey. Thanks
I wouldn't worry about it. The battery should last you a year or two even if you leave it on the cradle a few times per week. The batteries for this phone are relatively inexpensive. I would recommend using it in a way that fits your life style and buy a new battery in a year or so if you haven't upgraded to the Epic 5G
galibalmasanick
