Battery fell out during wipe, help!
pnicho
140
9
Well, my battery accidentally fell out while doing a factory wipe and now I can't get the phone to power up to the main screen anymore. I can get into the bootloader menus and that's about it. If I power it up, or do a factory reset, I see the htc logos a couple of times and then the screen stays black....but it's still on...just black. FYI it is unlocked and I ran the Clean flash tool and loaded up Amon Ra before this happened.
Re: Need help!
I am missing something about flashing a rom? When I did it with my other phones, I'd be able to access the sd card from the bootloader menu and install it from there. But I don't see the sd card or anywhere to get to it.
Re: Need help!
Hello,
Well I have some major problems I had ics 4.0.1 loaded on my phone and all i was getting was wifi no verizon signal so I called verizon and they had me do a few things with it and seem to screw it up it loaded up after reboot to the htc logo then a black screen. i tryed to load other roms and factory reset. cant seem to load at all past the htc logo and black screen. Please can someone help!!! Thanks Jess
Hello,
I'm assuming you're unlocked, rooted and installed a custom recovery like amon ra.
Sent from my ADR6425LVW using Tapatalk
Did you make a nandroid prior to all you problems?
Re: Need help!
I am unlocked and using the pgim.zip how ever type for the recovery zip because clock work didnt work. I can get into recovery and hbot but all my data is erase from sd card so I have nothing to reset the phone with. I am confussed lol
nope well i thought I had but cant find anything or were to load anything all i get is hbot and recovery and the normal tasks in recovery.
OK I would start from the beginning. Is the roms zip file on your external card? If so boot into recovery and wipe data/factory reset. Then reflash the rom. If necessary flash the appropriate boot image as well
Sent from my HTC Rezound using Tapatalk
You will have to resetup and reload all your apps and data. Make sure once you get setup and functional you make a nandroid.
Fyi Clockworkmod recovery has bugs. I recommend Amon Ra Recovery.
Charge the phone, then use CleanFLASH to flash the Amon Ra style recovery found HERE
Once you've done that, access the recovery menu and do a factory reset on the phone.
Finally, use the recovery menu to flash the ROM you have on your microSD card.
Gillian Kirton
