Battery help
tsargent347
121
ok i have loaded up comm rom 2.0 with pbj-50 and the battery is terrible, or well wacky, do i need to wipe batt stats and will that fix the problem? if i am to wipe batt stats what else do i need to do to make sure my phone runs properly?
wiping bstats in term emulator or cwm will help, if you do it properly. By that I mean: (and sorry, no offense, if you know all this already! )
1. Charge handset to 100%
2. Turn handset off and continue to charge to 100%
3. Re-power the handset on and charge again to 100% (which it might already be at when it reboots)
4. Wipe bstats in tu or cwm.
This is recommended every time you make a system change, such as changing kernel or ROM. I liked to do it every time i flashed anything that made a major change, such as kernel, rom or deep theme.
However, it will take up to a week before your battery gets accustom to your new setup. The battery likes consistency. If you change things (rom, kernel, theme) frequently than don't ever expect outstanding battery life.
I am on stock ED05 and am having the best battery life to date since owning my fascinate. 18+ hours some days on a single charge.
Good Luck!
Yeah im running ukb 2 pbj-50 and I take it off the charge after charging both on and off and it drops almost immediately to 95%..I think im on ed04..I went ahead n wiped stats earlier and the battery went back to 95% within 30 minutes..but ill just let it get to 5% and then fully charge n do that for a while n see hiw it goes..I can barley get like 3-4 hours on a charge with wifi only on cause that's all I use with the phone its not my everyday phone but may b if I can get this battery under control
I always had good luck with comavolt (kernel). You might try flashing that. I also recommend the ED05 modem, and which you should be able to Odin as a stand alone.
Also u need to give it 2-4 days for the battery and the rom to acclimate to each other.....sync together if u will. Become one together. ;)
ok i wiped batt stats and then turned the phone off and let it charge to 100%, then i let it die down to 5% and ledt it charge to 100% and then turned it off and charged to 100%, as soon as i take the phone off the charge, it reads 95%..any suggestions??
958ryan
